Ok so this is the disc and dongle I’ve gotwell then its an easy fix, show me a photo of the rear panel of the pc- the bit with the motherboard ports etc
This is pic of back of the 2nd pc we tried to use which all worked but the machine wouldn’t start a game when pressing the fire button to start, I think looking my friend has used graphic card in this?looks like its using a g31 motherboard
But the 7600 cars missing in first one is I’m guessing in the second one? Why would they have removed it otherwise?if you don't have the right hardware then the game will not behave, i bet if you put a 7600 card in there it would work- you could use any card as long as you had the right xp drivers installed
How can I find out motherboard to tell you what’s in second PC?what motherboard is in the 2nd pc?
you can bench test this pc, using a keyboard you can bypass the io board and start the game using the keyboard
Ok this is all over my head a little but I’ll try my best and take it step by step. Unfortunately though I need to use Arcade set up as I don’t have a DVI cable to plug old PCs into tv in house so can’t rig it up without using screen in Arcade.motherboards have the model number printed on them, also many show the model on the post screen
you can test certain global vr games on the bench with a keyboard, you can also check all drivers are correct by pressing windows key, click gvr shutdown and then goto device manager and check all hardware. Once you know all the drivers are correct then its highly likely the pc will function in the machine.
Ok great, if that makes it brighter. I’ll worry about it once I’ve managed to get it working again. Lolyou can adjust picture in test, digital vibrance and gamma
