M K L
1,036CR
To me it looks like this. So you connect a wire from the pad in the yellow circle to the anode of D506 (or to the resistor R500 connected to the anode).
7,138CR
ignore r500
on this picture is the red circle C313?
the blue circle i believe will be the where the anode of d506 needs to go via a wire link
Iv looked all over cannot see
C313
As I cannot see ident for this cap .. good chance it is c313
D501 has continuity to that cap posative leg 👍
Só yeh it’s cap 313
gunblade
8,508CR
mkl is saying what i am saying
install d506 and c333
put a wire on the pad marked by the yellow circle in mkl's pic, the other end of that wire goes to a free pad of the anode of d506, using a free pad of the cathode d506 run a wire to the your new resistor r318
personally I would do all the above but leave the connection onto r318 off, dummy load the collector of the HOT and of course isolate the pin of the HOT from the circuit and then read the voltage at the cathode of d506 - just to make sure you are getting 24v or close
7,138CR
Ok I got it
Don’t I leave a leg of d506 up and solder wire to it ?
Or do I have free pads ?
Not aware of free pads of 506 hete is a pic of solder side of d506 image.jpg
Jumps across them 3 traces.
Any pad of the 3 bottom pads is good then for the jumper wire ?
7,138CR
Thats 2 wires then in total
Yellow circle to anode of
D506
Cathode Side of d506 to my new resistor .
Ok then…. Simples 😬
Nah I got it 😊👍
Thanks a heap
And I should have the d506
Hopefully this weekend if not early week
I would love to do the dummy load if you can guide me on that also …
gunblade
8,508CR
use the pads that are free, it looks neater
install the diode and cap first then add the two wire links that need doing and use free pads/through holes
obviously the wire link from the transformer will need to solder side of the chassis but the other link can go component side
7,138CR
Got it ..
Jumper wire just pops through the through hole making it a neat job ..
Rather than have componants legs flying all over shop with wires solderd to them ..
R318 don’t have a free pad though ..
But d506 looks to have some
