Any interest in a Group buy in wigan 3x noir?
channel27
1,344CR
Just had a look in mine in case 2 doors in there but only 1 but the lcd panel is scratched proper bad at the top so thats gonna need replacing
Thanks for looking.
LG monitors seem to be the go-to: -
channel27
1,344CR
Random question for you knowledgable folks: -
These are Japanese cabs that run on 100v, yes?
Can I put a spare Naomi universal AC transformer internally in the cab to convert 240ac down to 100? I’ve got lots of them, either this Naomi one or several from Daytona twins
I assume there’s space inside?
channel27
1,344CR
You should be able to build a system in here without a 110v in sight, no?
Especially if you ditch the heavy monitors!
It depends what I end up putting in there tbh.
I guess the IO board needs 12 and 5v from somewhere and the existing PSU(s) run on 100v. If they're knackered I've got a Sun PSU to put in there but that'll also run on 100v.
Or I could just use a 240v PC ATX PSU
Crazy_1201
92CR
Indeed! In googling it I just found you on AP talking about the exact same thing!
You can absolutely do that. Access the transformer in the cab from the rear. Should connected to a power filter
If you unplug the connectors and take the base out you’ll see all the separate power units. Ones 12v, ones 24v, 5v and another i’m not 100 sure.
The monitor is the 24v so if you replace it you don’t need it.
The tube is powered directly 100v.
It’ a v simple cab once you dismantle it all.
