Astro fighter
Lurch666
4,518CR
I've fixed astro fighers but they have been the three boards in a cage type so I'm not familiar with this one.
Got to admit I'm puzzled at the picture of your monitor as it looks like there are just graphics is a circle so either it's a very strange boardset or your monitor has a problem as well.
If you can't find anyone better I don't mind having a look at the boardset for you.
6,092CR
It's a weird one. Does kind of look like a monitor fault, but if you're just getting those random characters on screen, and the game isn't playing blind, I guess it must be a board fault...
Body pop
24 (100%)
1,266CR
Great stuff ! I had given up on finding anyone and had it forsale
If I can get the sorted and eliminate it from causing the strange display I’d be at least half way there !:)
I’ll shoot you a pm
Body pop
24 (100%)
1,266CR
There are pots on the board .i wonder if they could be something for making screen bigger or something ?
Who knows ,but great news above that lurch666 is going to take the job on for me :)
It’s a stunning and rare cab so would be nice if it worked some day
favouredson
Super Star
1,260CR
That's a very odd bootleg.
The board is almost definitely a bootleg of Exidy's Crash (it even has CRASH written on the sound board) with several hacks to get it to run Astro Fighter.
The ROM board looks odd as the two ROMs labelled V & VI are upside down compared to the others. This may be correct (the SN76477 is the same) but it looks wrong.
The pots are for the various sounds rather than screen adjustments.
7,230CR
Body pop said:
Thanks Dave .not your kind of thing to repair is it ?
No not my thing and still unwell so not doing much at the moment. Last thing i want to do is promise something i am not going to be able to for fill.
Hopefully lurch can assist,
Body pop
24 (100%)
1,266CR
Cool mate ,hope your on the mend
And thanks for the recommendation.appreciated !
Body pop
24 (100%)
1,266CR
That’s an awesome piece of info there .thank you
I’ll stick a pic of the cab up ,it’s a weird Italian bootleg
Lurch666
4,518CR
Got the board but I'm a bit stumped at the start.
Making an adaptor for this and noticed the eproms are 2708 that need -5V and +12V to work but can't find any pin on the edge connector that connects to the relevant pins.
Can't find any other connector so there appears to be no way to supply the required -5V and +12V to this boardset.
I am correct in assuming 2708 NEED -5V and +12V to work and it's not just when the chip is being programmed?
Lurch666
4,518CR
I did and none of those seem to be connected to the -5V and+12V pins of the eproms either.
Looking at the exidy crash manual it's saying that +35V is supplied to the edge connector (J5-15 and J5-16) but the pins on the PCB lead to thin tracks so I'm thinking they can't be for that sort of voltage.
I'm thinking it's like pacman that takes in AC then converts it to the -5 and +12 volts as needed but still trying to figure out where it would connect.
@Body pop:
Could you try and see which wires from the PSU are connected to which pins on the edge connector.
I know pin 1 on the edge connector is +5V and pins 2 and 3 are GND but am wondering if any other wires from the PSU go to the edge connector.
favouredson
Super Star
1,260CR
The heat shields on the ROM board look like they may have voltage regulators connected to them. It may be that the odd voltages are generated there.
favouredson2021-05-27 22:05:26
