Electrocoin - Xenon / Neo Geo 4 / 6 slot /Goliath Restoration and Projects
Flyback2021
36 (100%)
1,971CR
Speaker sections - xenon .
7 completed now - Stripped , rust removed and ready for oxide primer. Also some metal reshaping involved.The bottom one was from
the outside xenon off eBay - came up well. Now onto the finishing and hopefully making a stencil to do artwork.
Flyback2021
36 (100%)
1,971CR
r-type
632CR
Thanks for supplying the link mate. I've only got one Electrocoin cab (Special Criminal Investigation) but I have two others that I think it would also work with.
5 cabs is awesome. Looking forward to the next update of yours!
Flyback2021
36 (100%)
1,971CR
Will work on most.control panels and easy to apply/ cut. Seems to keep overlay in place and adds some protection.
Flyback2021
36 (100%)
1,971CR
Another 3 speaker panels from
Xenon’s finished with red oxide primer and ready for a light sand finish and then spray. Using hammered black spray on all xenon parts closest match I can find to that used by electrocoin. Think the finish was favorited as hard wearing but also disguises bolt finishing well.
Flyback2021
36 (100%)
1,971CR
Little bit of fun as love painting and finishing.
Have a dozen or so white leaf buttons in various states from almost magnolia to burnt umber 😂 fear not some with the cig burn will be kept for authenticity also . Anyway wanted to try out dismantling and spraying with plastikote enamel. Must say I was
Quite impressed this is after a light wet and dry rub and 1 spray coat !
Put some non sprayed in for illustration purposes. Comparison on Neo geo panel - game select sprayed .
Flyback2021
36 (100%)
1,971CR
Mate bloody lost my screw, my 29" legs are all that is stopping me rotating the Monitor on my own, or just get another Cab...:cool:
I have to say it is not an easy monitor to rotate as I found out today. The weight of the monitor and frame is pretty substantial and not a pleasant combination of weight and reach - definitely won’t be doing too regularly.
I am almost certain that the monitor weight resting on top of the speaker metal section as you pull out causes the wood brace to strain under the speaker section. I have found in 4 cabinets this section broken and then had to remake as too weak to repair.0E083F60-C618-4CD5-BE9E-390248F7A33B.jpegFF23E0FB-7019-4159-A56F-98988D5BA067.jpeg
Sbdesign
SEGA collector
16 (100%)
1,671CR
Looking good, I picked up a Xeon in 23 or 24,
it was project local where the guy bought all new buttons and sticks, a lcd (no crt) and a game elf.
Wasn’t in bad condition.
He had a millipede bezel made, and the joysticks were transparent blue and yellow with bubbles in them :love:
There’s an idea for you (ducks quickly)
I have a crt. For it, and following your work on yours, which I’ll certainly refer too when doing mine.
I think on the speaker panel, I am missing one of the covers, at a guess right handside, do you have a spare at all?
Flyback2021
36 (100%)
1,971CR
Came across the flyer pic, that seems to have yet again different design on speakers
Interesting.
Not seen a version like this before and did wonder if a prototype?
Single player panel which I have not seen before but thought about making one ! vertical monitor and coin insert only on one side. No stenciling on side wings it seems and a white area around door where in most cases a perforated stenciled was used.
I am working on a stencil for speaker area currently.
Flyback2021
36 (100%)
1,971CR
Coin insert blanking plate ?
Will have a look.
