7,148CR
Other than that im curious whete my power supply for vcc of vertical oscilator currently is being drawn?
I hve asked Rick s well
Hence the effect im getting seems the issue rhat related to flyback causing over voltage to thr vcc
7,148CR
without this in front of me its so difficult to see the multiple mods you can do, i think you will also need to link the anode side of the diode to pin 3 of the supply transformer. you can see through hole for wire jumps all over this chassis
Yeh and also i need to disable current supply also right ?
But thats done just by lifting resistor leg out r318
gunblade
8,528CR
T501 is the supply transformer, pin 3 supplies the vertical ic in the original schem you linked to via d506 and c333
the large ceramic resistor you were pointing to looks to be R501 which is on the b+
