Initial D
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Ok, a new thread for all things ID related
Vamino
Insert coin(s)
22 (100%)
2,646CR
Well Martin dropped off the cab today.
It carries the battle scars of being battered in a UK arcade, but it's in OK shape I guess.
The seat has a crack, one side panel will need replacing as it's damaged, the seat doesn't lock into place as the lever is missing, loads of missing screws....thats without even testing it.
Does the floor look right to you guys?
I'm sure there is a floor panel missing?
There are no keys, is the key generic or will the lock have to be drilled out?
The general feeling I have is that us lot have actually rescued these cabs from a fate worse than death!
Cheers.
Vamino2013-09-21 21:05:10
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
I get a weird thing on ID3 running from CF on my ID1 cab.
When I pass the finish line the steering vibrates loads for about 4 seconds. Like when you go over the rumble strips. I can't see anything out of place in the game setup.
It plays fine apart from that. Annoying cos I've transferred my ID1 card to it.
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Beaps said:
Is your one the one from Terry then IDC?
Nope dude, it's one from this op group buy thing we got involved in, it should be coming up the road next week sometime but I'm at college till Friday and Friday is booked up
Outrun2
Colonel Outrun
1,153CR
That seat looks quite far back - looks like the entire base of the seat unit has been moved back a few inches. Maybe it had a very tall owner previously..
JohnnyChaos
325CR
tried 18 Wheeler and Crazy taxi in mine via cf cards today.
18 wheeler played, but the horn was on constantly.
Crazy taxi just locked up on the first splash screen :(
4,055CR
Where did your cab come from? One of the sides on mine used to do that. I never did get to the bottom of it as when I swapped the driver boards over between the two sides it stopped on both sides
simon325836
47CR
My CF solution is on its way...but I was wondering about the following games workinh on my ID2
1) F1 world grand prix
2) F355 ( i believe there is a single screen version???
3) what's the difference between club Kart and club Kart Euro
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
1. Not sure
2. Yes:
3. Just tracks I think?
4,950CR
Deano had a seat plate on ebay with rails and lock working
If you replace any broken side panels i'll take them as mine will be repaired and painted
bbz149
26 (100%)
1,608CR
F355 will not work in an ID Cab without spending a shat load on Boards and wiring! and not available for CF mod. Mine was a F355 Challenge 2, and I did think about keeping the boardset to play in the Cab, till I played it for all of 5 minutes
Chappy, I raise you 3
