Naomi Pi 'WiPi Netbooter' - compatible with Pi 34
Rob_bob_2k6
3 (71%)
203CR
Thanks for your help with that. That’s made it good enough to select game from the taxi cab. I think I’ll plug it into a joystick cab to set the assignments though, trying to do this with a gear stick and steering wheel is a tad painful.
Thanks again.
kerbdog
6CR
Just stumbled upon this when I was looking to update the my older Naomi PiForce Web setup - this is awesome!
For folks with just a basic stick/digital setup (or any other fixed setups) would it be possible to have a bulk 'Edit Game List' to exclude cab setup types? Only horizontal etc?
kerbdog2022-06-19 18:33:19
chunksin
733CR
Yep, that's on the list of features to add, it ties in with filtering games for the on screen menu. You can use the quick filters from the main menu or the 'edit game list' screen under setup to filter games for now
kerbdog
6CR
Awesome! Thanks Chunksin. Great to see active development. Turned on my Naomi cab after many months of sitting gathering dust, had great fun.
gr0don
109CR
Hey Chucksin, I a WiPi setup going fine for a few weeks until one day it stopped broadcasting an SSID to connect to. I tried other Wireless adapters and had the same issue. Given it was the older version of software I had I decided to flash the latest image. I can browse if connected through the RJ45 but I still don't have a wireless network to connect to. Can you tell me if the settings here are correct? I have never changed them.
Thanks,
Gordon.
chunksin
733CR
That's odd, could the wifi have got damaged on your pi? it will broadcast the WiPi-Netbooter SSID by default, your interfaces file looks fine for hotspot mode too. I guess you could try a vanilla install of the Raspberry Pi Desktop OS and test your wifi is working OK
gr0don
109CR
Thanks for the help. I installed a Pi OS and the wifi was working fine on that. I re flashed the image on to the SD card and still have the same issue no not sure what is going on. All of the USB ports seem to be working. At the moment I only really need to to boot Crazy Taxi so I stuck it in sever mode but all I get is "Error 31 - This game is not acceptable by the main board". I tried with Open JVS enabled and disabled. Also swapped in another Naomi with a different BIOS chip and got the same result. Am I missing something? I would get a new Pi to test with but the prices of them are silly just now! I may try hooking up an old laptop for the time being.
Thanks,
Gordon.
jerryspaghetti
32 (100%)
1,756CR
Having a mare trying to sort this! My hardware/practical knowledge is decent but I fall to pieces with technical IT stuff!
I've downloaded the files (14nr zips), extracted them and now I have 14 folders with one disc image file in each.
So do I drag all 14 extracted folders onto my SD card and that's it?
chunksin
733CR
Just extract the first file using WinRAR, you should end up with a single .img file that you write to SD card using Etcher or Win32DiskimagerChunksin2022-07-22 20:40:09
Suteneko
135CR
I'm wondering if the 6.1.8 update broke the time hack as I updated to that earlier today and now I am getting "Gateway Error 33" issues after a while of playing where with on 6.1.7 i was getting no issues.
Can't see anything obvious on my side. Reverting to 6.1.4 to see if this problem goes away.
Suteneko
135CR
Ah i thought i was going insane, checking cabling, voltages etc
Thanks so much for the quick response!
Just got 6.1.4 back up and running, might put off updating until you get the SRAM backup feature released though now. Which is huge for me :)
Suteneko2022-08-03 15:09:51
chunksin
733CR
It's coming soon, I just need to stop adding extra stuff in and call it done! if you're happy to test I can provide you with the update
Suteneko
135CR
I would love to but even just putting that replacement file onto my image is beyond me.
I gave it a try and tried for first time to use ssh via windows but somehow can't get past the password, think i screwed it up.
Shame you can't just see root via windows explorer.
Reverting back to 6.1.4 again ^ ^;
Suteneko
135CR
Finally figured it out and can SSH properly and sftp easily into it now.
So updated to latest version and transferred over the replacement netdimm.py
Way too much "learning" for today.
chunksin
733CR
Check your updates, new release is out, in brief:
SRAM save and restore in OSM (use the test switch on the Naomi to access the menu)
ID card emulator refresh - now includes JP support
Naomi netdimm hori/vert setting for OSM auto filter
New settings definition files for OSM (hold start on a game to access the menu)
Fix time hack code (I broke it)
MiFare card support 1k/4k
OpenJVS Hat Rotary support
OpenJVS Hat serial port support for card emulator
NFC netbooting
Main Menu System filter (toggle in Options)
Basic File Manager with console (available under Manage WiPi)
Suteneko
135CR
Been looking forward to this update for quite some time now.
Thank you so much for integrating a SRAM backup.
Was having issues getting into the OSM but I guess I just needed to set OSM mode to REPLAY because I was using single boot mode and powering the Pi separately to the NAOMI.
Gone back to single boot mode without OSM for now as it seems "quirky and slow" to me.
Suteneko2022-08-20 00:11:40
