Outrun Deluxe (Turbo De-conversion) Restoration
tin
655CR
Wow Clarkey you are making me not want to strip down and paint mine with the amount of elbow grease that must have gone into that!! I think I might leave it a wreck and assembled :)
clarkey
94CR
Body work continues.
Sanded down all the filler that was applied after the first round of primer.
Applied more primer, then wet sanded all of it.
Then began masking.
Finally applying some paint.
Seat grey.
Then started on the black.
Been pottering around doing other little jobs in the evenings.
Rear lights were luckily present, however one was on inside out for years (you can see it in the pic of it on site) so was very scratched, repainted both.
Before
Paint
After
Silver paint on the wheels, then masking and all the red to do. Struggling to find a good color match for the red at the moment so going to do a few tests on some scraps.
clarkey
94CR
Thanks all, glad people approve, pleased so far for a home job.
While
I have been painting I repaired the dash as it was badly meted and
burnt, as I have zero chance of finding a NOS one any time soon I
decided to repair it.
Before, melty.
Cut off the burns with a scalpel.
Then filled the dents left behind.
Primed (with a flexible plastic primer)
Painted, it's not 100% but it looks much better.
clarkey
94CR
Finishing the seat.
Removing the masking, scared over overspray at this point, this piece is a huge lump and a pita to mask.
Really pleased.
Next job is to clear coat all the painted parts, then put them back on the machine
clarkey
94CR
Cheers always appreciate the comments,
Painting fixtures and fittings, so many screws and fittings in this machine!
Welded in a new fitting for one of the leg levelers as the spot welds had failed.
All the wood was painted and refitted.
Pedals were stripped and refurbed, they have been painted for now, eventually they will be re-chromed.
Before
After
Before
After
clarkey
94CR
Side wood.
The brackets etc were very rusty so stripped cleaned the side wood repainted where needed and refitted.
Before
After
Gear lever bracket, where the gear lever had been replaced with a turbo one the bracket had been butchered. So I had to cut a new bracket from some galvanized steel bend to shape and drill and tap.
As it was.
New bracket fitted.
Drilled and tapped.
Sorted.
Meanwhile the clear coat is all done, now going to reassemble the body work.
