Pentranic chassis screen jumps
7,148CR
you need to remove the plastic frame from the chassis to clearly see where everything goes
then send a good high res photo of underneath of the chassis
Will do shortly
Sorry been sent on a charity mission round every buisness in my town for primary school ..
Few swifts and a burger and I’m good👍
Moneies raised .. back to chassis ..
Will get plastic off now .IMG_7545.jpegIMG_7552.jpegIMG_7548.jpegIMG_7546.jpeg
If you Want closer in on an area in particular 👍
gunblade
21 (100%)
8,631CR
pin 11 of flyback goes to q401 which should be a bu2520d, centre pin of course is the collector
pin 8 of flyback is ground
desolder collector of HOT so its completely isolated from the pad, add lamp between pin 11 and pin 8
7,148CR
Ok .. like this ?
Lacking full pad of
Solder also om these pads ..
Should
I top em up with solder ?
7,148CR
yes, bit severe with the poor transistor leg, would have been cleaner to remove entire transistor
yeh I would have done removed completly but I lost half the pad of collector Só
Dicided it was going to possibly cause more damage to the other 2 pads .
I’m hooked onto R501
Just going to look at schimatic to see if R501 is the b+
Bulb 150w
gunblade
21 (100%)
8,631CR
yep vr501 is b+ adjust but that is not the aim of this exercise, you are dummy loading the b+ to read the 25v line. reading the b+ is bonus and you can mark down the level for future reference
