Pentranic chassis screen jumps
gunblade
9,072CR
you have not completed the exercise, the whole point of this was to locate and connect a 25v clean supply line to the ic - you have not done that yet
how do you what pin of flyback goes to collector of the HOT? easy look at the schematics or follow the track of the HOT collector
8,249CR
Cool ..
Só for 25v line clip on vcc leg of ic ?
gunblade
9,072CR
no you are not understanding my process, you do not know if you are going to get 25v so you need to prove it - you should isolate the resistor you replaced from the ic and with light bulb attached as dummy load as it is now you need to read the voltage you are getting on that resistor to make sure its correct
8,249CR
Ok
Só loft resister back out of circuit ..
Clip onto its leg and let’s see what the voltage is being supplied.
I had to run down to kids football
But back home in a few mins 👍
